Over/underadjusted steering box?
Old Nov 5, 2020 | 01:21 PM
Liddlez's Avatar
Liddlez
Default Over/underadjusted steering box?
Firstly, I apologize for posting so much, and I thank you all for all your help, and feedback! I’m a DIY’er because I don’t trust mechanics at all, I attempted to adjust my steering box, and due to my terrible sense of direction I first un-tightened the nut then the adjustment screw. I noticed that the adjustment screw does not “unscrew” all the way. Like, you can’t take it out. No, I wasn’t trying to, again loss sense of direction. I know it’s “lefty loosy, righty tighty” but the position of the bolts/nuts vary. I noticed the steering wheel feels okay, but it was leaking from the screw. Why is that? Thank you!
Old Nov 5, 2020 | 01:35 PM
Ramman18's Avatar
Ramman18
If it's leaking then it's way too loose. Should never adjust the pre-load anyway. Just get a new box.
Old Nov 5, 2020 | 01:45 PM
Liddlez's Avatar
Liddlez
If it wasn’t meant to be adjusted, it wouldn’t be there, there wouldn’t be forums on it, and most importantly, the adjustment instructions wouldn’t be in the factory service manual, which they are. Secondly, most people say that steering boxes are not guaranteed. You may end up with much worse. If it was a certainty, I most definitely would opt out to replacement.
Old Nov 5, 2020 | 01:58 PM
There are actually two adjustments for the steering box, and it is *easiest* done off the truck. As you stated, the procedures are in the service manual..... That said, the adjustment can make up for some slop, but, if the box is really worn, there is nothing else you can do, besides replacing it. You are correct in that getting a reman unit from the local parts store is a real crap shoot. The *new* box might be worse than the one you are replacing. If you REALLY want your steering to be tight, and accurate, best solution is to replace the box with a QUALITY reman unit. Redhead, or Borgeson are good, There is also Blue Top.... the latter is relatively new on the scene, and I have not see any reviews on them yet. Borgeson requires modifying the box, or replacing the intermediate shaft to get it to work. They ain't cheap, but, they ARE good. Of course, the rest of your steering gear needs to be in good shape too.
Old Nov 5, 2020 | 02:18 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
There are two adjustmcents?
Old Nov 5, 2020 | 02:23 PM
MoparFanatic21
This got my curious do I looked up Auto Zone prices on boxes for my 2500. The cheap one is $220, then they have two "premium brands" for $750 and $850. HOLY COW THAT'S MORE THAN A REDHEAD
Old Nov 5, 2020 | 09:20 PM
Yep, the familiar one with the tension screw and jam not on top of the pitman shaft, and there is also an adjustment on the front of the box, where the sector shaft comes in.
Old Nov 5, 2020 | 09:36 PM
2bit's Avatar
2bit
These are new boxes, not reman for a 2000 1500
LARES 11416 Info
Power Gear (Only 1 Remaining)
$334.79
BBB INDUSTRIES N5020128 Info
FitsPower Steering; Extended Cab or Quad Cab
or135.0" Wheelbase; Power Steering; Standard Cab
$363.99
Old Nov 5, 2020 | 11:45 PM
Ramman18's Avatar
Ramman18
Geez Louise, change your diaper. Back before you even dreamed of owning one of these trucks, there were threads on steering gears everyday, and the actual consensus was/is, including from reputable rebuilders, is that the adjustment is not to take slop out of the box. It is to set the preload at the rebuild stage or manufacturing stage. It should never be done after the box has worn out. In fact, Redhead puts a lock on it and WILL NOT ALLOW RETURNS if the end user removes the lock to adjust it. Get off my back if you didn't want advice.
Old Nov 6, 2020 | 01:01 AM
Liddlez's Avatar
Liddlez
Whatever you say ma’am.
