How to calibrate blend door actuator?
Old Nov 5, 2020 | 03:32 PM
Mark Leroy Howell's Avatar
Mark Leroy Howell
Default How to calibrate blend door actuator?
So I'm rebuilding my HVAC box, and I want to make sure the blend door actuator is going to work as it should before I put the dash back on. Any tips on the best way to test it before I put the dash back together?
Old Nov 5, 2020 | 06:19 PM
Moparite's Avatar
Moparite
What year? Don't think there is any adjustment with the pre blend door motor types except to get the cable adjusted with the door for max heat.
Old Nov 6, 2020 | 12:40 PM
Mark Leroy Howell
It's a 2000. Not sure what cable you're referring to.
Old Nov 6, 2020 | 12:42 PM
Procedure for that is in the Service manual. Get one here. On the older trucks, the blend door is cable operated.
