Rear axle swap?
Old Nov 18, 2020 | 07:38 PM
All 2nd gen 3500s are dual real wheel. Also, the D80 Dually rear is going to be narrower than a single rear wheel rear.
That said, the D60 is no slouch. Unless you are running big power numbers, AND huge tires, AND beat it to death off-road regularly, it should hold up just fine.
Old Nov 18, 2020 | 08:24 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
All 2nd gen 2500s are dual real wheel. Also, the D80 Dually rear is going to be narrower than a single rear wheel rear.
The first statement has me confused. Can you explain? Lol
Old Nov 18, 2020 | 08:27 PM
I did a MoparFanatic, and have a typo. That should be "all first gen 3500's are dual rear wheel."
Ok, you can point and giggle now.
Old Nov 18, 2020 | 08:33 PM
00t444e's Avatar
00t444e
Why would an axle be too much for the transmission? People put 1 ton axles in Jeeps.
Old Nov 18, 2020 | 08:36 PM
MoparFanatic21
I thought you were making a joke saying all 2500s have two rear wheels (one on each side) . Hey my life is hectic don't always have time to proof read. does your truck have the under rear seat storage?
Old Nov 18, 2020 | 08:41 PM
00t444e's Avatar
00t444e
The 2nd gen 2500 Cummins manual trucks had a SRW Dana 80 in the rear.
Old Nov 18, 2020 | 10:42 PM
MoparFanatic21
That's a hybrid Dana 70
Old Nov 18, 2020 | 11:04 PM
00t444e's Avatar
00t444e
Nope its a true Dana 80 with 35 spline shafts.
Old Nov 19, 2020 | 01:53 AM
MoparFanatic21
No it's a Dana 70U which has a Dana 80 pumpkin but 70 axle tubes (hence why they kneck down at the wheels.
Old Nov 19, 2020 | 06:23 AM
00t444e's Avatar
00t444e
The Dana 70U is a different axle with smaller tubes and 32 spline shafts, it was used in the auto 2500s.
