Steering gear box
Old Nov 28, 2020 | 07:20 AM
John Carter's Avatar
John Carter
Default Steering gear box
So yesterday I was involved in a wreck not much cosmetic damage. Broke the shift from the gear box to the pitman arm. Should I replace the pitman arm when I replace my gear box. Also since my truck is lifted 4.5in should I get a drop pitman arm opposed to the oem. I'm not sure if it has the drop pitman arm since I bought it already lifted
Old Nov 28, 2020 | 10:04 AM
Wow. I haven't seen that one before.... Usually, other stuff breaks first...
But yeah, if the pitman arm isn't bent, could probably re-use it. Provided you can get that piece of shaft out of it.
Go with a Redhead steering box. Direct swap, and a much better quality than the reman units you get from the parts store.
Old Nov 30, 2020 | 07:23 AM
ramfan45619's Avatar
ramfan45619
Wow, hope everyone is ok after the wreck. What is that fluid on the pavement, hopefully not coolant?
Old Nov 30, 2020 | 08:07 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Power steering fluid
