multiple misfires and injector codes
Old Dec 4, 2020 | 02:31 AM
ReadRam's Avatar
ReadRam
Default multiple misfires and injector codes
Was Driving about 40 mph and boom, out of nowhere engine started bucking, Limped it home about 4 miles while CEL was flashing, 191,000 miles on engine. Was deja vu like my prior truck, a 99 with 230,000 miles where a valve spring had broke. I told the shop I thought I broke a valve spring. They had multiple misfire and injector codes and came to the conclusion I needed a new PCM. No injector pulse from PCM for 3 cylinders.. Put new PCM in today and still had misfire on #7. Turns out the #7 has a broken valve spring, which they are going to do for free??? My question is, what are the odds a broken valve spring and the PCM would malfunction at the same microsecond in time?
Any thoughts appreciated, thanks.
Old Dec 4, 2020 | 07:12 AM
It's possible...... I have seen stranger things.
Old Dec 4, 2020 | 12:11 PM
ReadRam's Avatar
ReadRam
This will get me back on the road for the short term, but will be wondering when the next valve spring is going to break. Can you recommend a source for a reman engine? I've replaced or had fixed just about everything else so far. Maybe it's time to throw in the towel. Thanks.
Old Dec 4, 2020 | 05:57 PM
Jasper is actually halfway decent..... and their warranty support is good too. (used to deal with them on a regular basis, when I did that kind of thing for a living.) Your local parts store can likely get you one as well, and if you have issues, you have the advantage of being able to go in, and talk to a real human being, in person.... not some anonymous voice on the phone.
Old Dec 5, 2020 | 10:45 PM
ReadRam's Avatar
ReadRam
Put new valve spring on #7, then put original PCM back and my truck runs good again. Logic tells me I should have all the springs replaced because I might not be so lucky next time. Compression is still adequate. Is it worth just replacing all the springs.
Old Dec 6, 2020 | 07:43 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
If the rest of the engine is in good shape I would say it's worth it. I would do a compression test (sounds like you already did) and a leak down test.
