Shifting issue
Old Dec 4, 2020 | 10:42 AM
Firefighter355's Avatar
Firefighter355
Default Shifting issue
I have a 96 Dodge ram 1500 with the 59 been having some issues with it lately he was miss firing sputtering and not shifting good I replaced the computer I replace the coil the spark plug wires the two sensors on the transmission The speed sensors both of them but it’s still shifting really bad especially between 45 and 55 mile an hour shift at high RPMs and then it will shift and then shift back up like it’s slipping between second and third gear don’t know what else to do with it I’ve had a chance to rebuild couple years ago and had a tranny filter and fluid change about six months ago and it has never actually gone away any ideas
Old Dec 4, 2020 | 05:58 PM
Is the engine running good now??
Old Dec 5, 2020 | 08:48 AM
Moparite's Avatar
Moparite
Do you know what a period and comma are and how to use them? Was the plenum gasket issue addressed? Any codes?
Old Dec 5, 2020 | 02:10 PM
Firefighter355
Yes motor is running great now just the shifting now. I’m just out of ideas
Old Dec 5, 2020 | 02:13 PM
Firefighter355
Yes moparite, I do know what they are!! I’m asking for advice on my truck not my English thank you!! I have not tried that and no codes since new computer
Old Dec 5, 2020 | 09:30 PM
Could try replacing the governor pressure sensor and solenoid, also, make sure the TV cable is adjusted properly, and works the way it is supposed to.
Old Dec 6, 2020 | 11:45 AM
Firefighter355
OK thank you I will give that a shot and see what happens and I will get back to you as to what I find out
Old Dec 6, 2020 | 12:28 PM
Might wanna adjust the bands too, while you are in there.
Old Dec 8, 2020 | 09:17 AM
Firefighter355
I will do that just a little adjustment on the TV cable made a huge difference
