Horn Trouble
Old Dec 7, 2020 | 11:54 PM
DerTruck's Avatar
DerTruck
If the truck honks when using the remote lock the relay etc is working fine. The CTM is connected to the wiring from the horn buttons via a joint connector under the dash. It's likely the clock spring has an issue, or maybe the wiring along the steering column. Look for a fairly thin black/red wire.
Old Dec 8, 2020 | 01:42 AM
V10 Newbie's Avatar
V10 Newbie
Thanks. I will see if I can see anything.
Old Dec 8, 2020 | 05:20 PM
V10 Newbie's Avatar
V10 Newbie
[QUOT=MoparFanatic21;3500589]I do own a test light but unfortunately I don't have access to a 2nd person tonight. If you have a suggestion I might be able to try it tomorrow. Thanks![/QUOTE]
Ok on the relay you would stick the test light in pin 85 (look under the relay the pins should be labeled) it will be a Black/Red wire. Connect your test light to power as the horn switch ground the circuit. You might be able to see it from inside the cab or reach in the window and press the button. It should light up. Let me know what you find[/QUOTE]
I tried the test light on terminal 85, no light. Does that mean the problem is in the steering column?
Old Dec 8, 2020 | 08:54 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I tried the test light on terminal 85, no light. Does that mean the problem is in the steering column?[/QUOTE]
Sorry I forgot to mention you have to press the horn button. Did you do that?
Old Dec 8, 2020 | 09:09 PM
V10 Newbie's Avatar
V10 Newbie
Yes I tried the horn button on both sides with no success.
Old Dec 8, 2020 | 09:55 PM
MoparFanatic21
Then yes you have an issue with the wiring from the switch to the relay. Do you own the FSM? If not download it from the FAQ section wiring is in 8W
Old Dec 8, 2020 | 10:48 PM
V10 Newbie's Avatar
V10 Newbie
Ok. Thanks for your help.
Old Dec 9, 2020 | 12:12 AM
MoparFanatic21
You are welcome!
