Parking/Rear Brake Issue
Old Dec 16, 2020 | 09:09 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I just pulled mine all apart, cleaned everything REALLY well, replaced the easy to get hardware, and reassembled. (I had to do wheel cylinders anyway..... they were leaking.) Don't forget to do something with the swept surface of the drums...... I ended up just hitting them with some 80 grit sandpaper, as I couldn't find anyone that would turn them for me. (and my buddy sold his brake lathe....... I may end up buying one........ maybe do a side business. ) I used antiseize on the adjusters. Lubes them up, keeps them free, but, is thick enough, that they don't turn when the wind blows from the right direction.
I think you may be right that the adjusters are winding them to tight. As today in the snow you BARELY and I honestly mean barely hit the brakes and the rear wheels lock up. Now I am 80% sure I have air in the lines because when I did the restoration I put new lines on it and the ABS was acting weird. So I think I pushed the air out of the module.
Any idea on the parking brake issue?
Also today with 4wd engaged I got a shake and a whistling sound. You think it could be the bar u joint that I posted about with to much side to side play?
Old Dec 17, 2020 | 06:46 AM
Whistling? That, I would have to hear......
Grab a spare body, and bleed your brakes out good, maybe the fronts just aren't getting good pressure?
Old Dec 17, 2020 | 12:34 PM
MoparFanatic21
I believe the fronts are, but I planned on bleeding them anymore. Right after I beat up mother nature
Old Jan 12, 2021 | 08:18 PM
MoparFanatic21
Updating the thread. Parking brake don't work at all anymore and won't know anything until I get the rest brakes off. I'm afraid I may have stretched the cables
Old Jan 12, 2021 | 10:12 PM
New cables will stretch a bit, Old cables can stretch a LOT, depending on condition..... If it's just a little, should be able to readjust the cables, and call it a day.
Old Jan 12, 2021 | 10:34 PM
MoparFanatic21
I have the adjuster almost maxed and it isn't working. I think I may have gotten the wrong self adjusters. Will try to adjust them manually and see if it helps. I doubt it though because my brakes are perfect just funky ABS
Old Feb 27, 2021 | 11:44 AM
MoparFanatic21
So lost brakes and seen fluid coming from the drivers side drum. Was putting off looking at the emergency brake until summer or my garage is done. Kind of hard to open it up :b and I THINK I found my problem. I put both big shoes on the driver's side lol. Didn't get it back together as it started down pouring
Old Feb 27, 2021 | 05:12 PM
Oooops.
Time to replace wheel cylinders, and shoes again?
Old Feb 27, 2021 | 05:40 PM
MoparFanatic21
Oooops.
Yeah just the one wheel cylinder and the shoes because when they get a grease on them I don't bother cleaning them. Lifetime warranty on brakes at AutoZone. I'm afraid though I might have stretched the parking brake cables
Old Feb 27, 2021 | 08:35 PM
If the other one is of the same vintage as the one that failed, just bite the bullet, and replace it. Otherwise, you just KNOW next week you will be seeing fluid dripping out of the other one.
