2002 5.9l 2500
Old Jan 17, 2021 | 09:15 PM
  #21
00t444e's Avatar
00t444e
Compression tester generally just screws in to the spark plug hole.....
What if there is no spark plug holes?
Old Jan 17, 2021 | 09:20 PM
  #22
If it's a gasoline engine, there are spark plug holes.
Old Jan 17, 2021 | 09:41 PM
  #23
00t444e's Avatar
00t444e
He has a Cummins.
Old Jan 17, 2021 | 09:50 PM
  #24
Ceejaydee88's Avatar
Ceejaydee88
He has a Cummins.
this is correct. This is why I am at a loss.
Old Jan 18, 2021 | 06:51 AM
  #25
In that case, there are adapters you need, and I *think* the compression tester goes in in place of the injectors? Not really sure on that, I don't generally do diesels.
Old Jan 18, 2021 | 07:02 AM
  #26
00t444e's Avatar
00t444e
You need this. https://www.tooldiscounter.com/produ...RoCGUEQAvD_BwE
Old Jan 18, 2021 | 05:03 PM
  #27
Ceejaydee88
thanks. I have just passed by the compression test and I will just do a leak down test when I get the block on the stand. But I assume I have to plus the hole that the fuel rail screws into? Unless this part does not allow the air to escape around it. If so I will do the compression test prior to removing anything further. So far I have the whole front clip removed. All the rads minus the ac rad(have to get system evacuated)
Old Jan 18, 2021 | 07:25 PM
  #28
00t444e's Avatar
00t444e
You don't have to plug the fuel feed tube holes, the tool seals at the bottom and air can only go out the top hole.
Old Jan 19, 2021 | 05:45 PM
  #29
Ceejaydee88
What is this? Is it worth replacing and reinstalling it? It was like this.
