Crank but no start
Old Dec 30, 2020 | 03:39 PM
Justinm4's Avatar
Justinm4
Default Crank but no start
So i have a 98 with the 5.2l 318 single cab and i was driving the other night and lost power in the throttle, after a few hours of trying stuff i gave up and got a tow. I like to belive its a fuel pump but im not 100% sure. I recently changed all plugs and dizzy cap n rotor.
I put a new battery in also.
then the other day i tried to start it and it said i had no furl even tho i had a full tank. The next day it was reading full. Any input will help. Thanks!
Old Dec 30, 2020 | 06:10 PM
Bad connection at the fuel pump module, or, it is seriously considering failing......
Old Dec 30, 2020 | 07:11 PM
Justinm4's Avatar
Justinm4
do you know where thr module for it is located?
Old Dec 30, 2020 | 08:03 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
On the fuel pump
Old Dec 30, 2020 | 10:10 PM
The module itself. Essentially, the part you replace when the pump does fail. It inserts into the gas tank.
