1998 Dodge Ram 1500 Turns over not starting
Old Jan 2, 2021 | 03:35 PM
Gonzo Monkey's Avatar
Gonzo Monkey
Cool 1998 Dodge Ram 1500 Turns over not starting
Now when I turn the key on all the lights and bells and meters do their thing and i can start the truck, now when I turn on the key the lights and bells go on but the meters move a centimeter but not on like usual, they usually go all the way then return to where they are supposed to be at like the ammeter doesn't go to 14v like normal, I heard something zap when I turned the key on and that's when I noticed the meters not doing their check and engine will turn but won't start, I checked all the fuses and relays all good, fuel pump has always been quiet and can hear it when i open the fuel cap
Old Jan 2, 2021 | 08:17 PM
Ceejaydee88's Avatar
Ceejaydee88
Try taking they key out. Lock the driver door. Then from the outside unlock the door with the key a few times. Sounds like the anti theft to me.
Old Jan 3, 2021 | 03:21 PM
Gonzo Monkey
can I bypass the ASD relay?
Old Jan 3, 2021 | 04:18 PM
No. It's there for a reason, and the PCM isn't energizing it for a reason. Need to find out why. Might just be a bad relay. Swap it with the horn relay, see if anything changes.
Old Jan 3, 2021 | 05:04 PM
DerTruck's Avatar
DerTruck
Originally Posted by Gonzo Monkey
...they usually go all the way then return to where they are supposed to be....
That is not how it is supposed to work, I'm guessing you are missing permanent power to the cluster. That should not cause a no-start though. What voltage do you have at fuse 17 in the inside fuse panel with ignition on/during cranking ? The ignition switch might be suspect.
Old Jan 4, 2021 | 01:30 PM
Gonzo Monkey
I swapped relays all relays test out, I will check voltage at fuse 17 then try diagnosis on cluster
Old Jan 7, 2021 | 05:52 PM
Gonzo Monkey
Tried fuseblock everything is good hooked up code reader and it will not communicate with the puter maybe that's the big problem,
Old Jan 7, 2021 | 10:09 PM
That would be a problem..... check fuses in the fuse block on the side of the dash as well.
Old Jan 8, 2021 | 12:46 AM
Gonzo Monkey
Cool
Talked to a dodge guru he came over and did all the things I did and came to the same conclusion I need a new Brain....for the truck lol
