98 318 fuel issue
Old Jan 9, 2021 | 10:22 PM
Justinm4's Avatar
Justinm4
Default 98 318 fuel issue
So i reccently had what i thought was a fuel.pump quit on me.
i replaced the pump, checked all fuses and everything, theres spark and it fires when i spray fuel into the throttle body.
if anyone has any suggestions it will be helpful.
Old Jan 10, 2021 | 10:20 AM
Getting power to the pump? Does the gas gauge work? How much gas in the tank?
Old Jan 10, 2021 | 10:56 AM
Justinm4's Avatar
Justinm4
Gas gauge works and the tanks at 3/4, but the harness at the pump end isnt showing any power
Old Jan 10, 2021 | 11:05 AM
If you bypass the relay, do you get power? (pin 30, to pin 86)
Old Jan 10, 2021 | 07:31 PM
ol' grouch's Avatar
ol' grouch
Swap your a/c and fuel pump relays in the relay box. If it starts then, you've got a bad relay. It's winter so you can go a bit without a/c. Get a new relay and swap the a/c one back.
