94 engine block into a 2000
Old Jan 17, 2021 | 07:48 PM
Junkaf_5.9's Avatar
Junkaf_5.9
Default 94 engine block into a 2000
Hey everyone, I broke a connecting ron in my 2000 dodge ram 5.2 4x4, someone local has a 5.2 out of a 1994 jeep. My question is can I strip the engines down and use the 94 block and rotating assembly with all the 2000 stuff?
Old Jan 17, 2021 | 07:58 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
If the mounts are the same yes
Old Jan 17, 2021 | 08:02 PM
Junkaf_5.9's Avatar
Junkaf_5.9
that's what I need to know if everything will swap over and bolt up being 6 years older
Old Jan 17, 2021 | 09:01 PM
MoparFanatic21
Unsure don't know Jeeps
Old Jan 17, 2021 | 09:05 PM
Isn't the starter motor on the opposite side?? 92 was the first year for the magnum though, so, theoretically, it *should* work. Have to use the intake and sensors of the dead motor though.
Old Jan 17, 2021 | 09:06 PM
MoparFanatic21
If he uses his transmission it would stay in the same place
Old Jan 17, 2021 | 09:08 PM
True. Starter mounts to the trans, not the engine.
Old Jan 17, 2021 | 10:29 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
As far as I know they are the same. Can you get the engine to do some measurements on it? Is it already pulled from the Jeep? It wouldn't take much to just measure where the mounts are on your block and then measure his. But I have never heard anyone talk about any issues swapping engines around thru the years on any of my Jeep forums.
