95 ram exhaust back fire after intake plenum and header install
Old Jan 23, 2021 | 05:45 PM
  #21
BigRedRam95's Avatar
BigRedRam95
Black for oil? Or soot? I don't think changing your plugs is going to make any difference. I think your problem lies elsewhere. Do the compression test. See what your numbers look like.
I was soot. I’m going to do a compression test as soon as I find my tester. I had a my toy hauler and truck broken into and I can’t remember if my tester was in the trailer with everything else that got stolen or not.
  #22
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Isn't that the even side? If so that's #8 and that's a sign of a bad Plenum, right?
Old Jan 23, 2021 | 06:11 PM
  #23
And also possibly a clogged cat.....
Old Jan 23, 2021 | 06:28 PM
  #24
BigRedRam95
yea it’s 8 for sure. I pulled the intake and did the plenum gasket that’s what started the truck do this that was about 2 years ago. At the time I thought it was just because it was running off the open headers but that doesn’t seem to be the case here.
Old Jan 23, 2021 | 08:25 PM
  #25
Are the plug wires routed properly? Firing order??
Old Jan 23, 2021 | 08:31 PM
  #26
BigRedRam95
im pretty sure they are. I found my compression tester. I’m going to pull all the plugs and try to check it tomorrow. And check to make sure the wires are routed correct.
  #27
Let us know what you find.
Old Jan 23, 2021 | 08:40 PM
  #28
BigRedRam95
I know a while back their was a post about how to route the plug wires and which clips they should be in. But I can’t find it.
Old Jan 23, 2021 | 10:24 PM
  #29
I think it is in the DIY/FAQ section..... Might be stickied, but, don't recall.
Old Jan 24, 2021 | 08:30 AM
  #30
BigRedRam95
So just thinking out loud here but could a crankshaft or camshaft sensor cause the issue? What controls the fuel injector timing?
