2000 tc sticking
Old Jan 30, 2021 | 10:12 PM
CEW1978's Avatar
CEW1978
Default 2000 tc sticking
I had to shift into fwd pulling away from the hay stack. After feeding and driving 6 miles down the dirt road at rancher speed I turned onto the highway. Started hearing what sounds like gears rattling in the tc. I have tried shifting back and forth, backing up a pretty good distance, killing it and shifting and it still seems like it’s partially engaged. Any ideas?
Old Jan 31, 2021 | 10:22 AM
Moparite's Avatar
Moparite
Driving on solid ground(asphalt) in 4WD can damage the transfer case.
Old Jan 31, 2021 | 11:00 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Sometimes what happens is the CAD fails AFTER you engage 4wd. Switch the vacuum lines and see if the noise goes away
