P0171 (System too lean)
Old Jan 30, 2021 | 11:36 PM
Liddlez's Avatar
Liddlez
Default P0171 (System too lean)
Could low fuel pressure (33PSI) cause this? Prior to replacing the pump I was running rich. She also has a hollowed out catalytic converter. (Haven’t had the chance to take her into the muffler shop.) Thank you. (5.9 Magnum 360 V8)
Old Jan 31, 2021 | 10:00 AM
Moparite's Avatar
Moparite
33 Is to low, You should have 49 psi. Is this with the new pump?
Old Jan 31, 2021 | 03:20 PM
Liddlez's Avatar
Liddlez
It was a “new old stock” OEM pump. BUT it was for a 1500, not 2500.
Old Jan 31, 2021 | 06:28 PM
They both use the same pump. Might be a difference in gas tanks.... but still, 33 ain't right.
Old Jan 31, 2021 | 06:40 PM
Liddlez's Avatar
Liddlez
Yes, I figured. I’m just waiting for this gas tank to deplete so I can drop it, and put my Delphi one back. Only reason I got this one was because I liked the design. Extra filtration vs. the Delphi that had a sock.
Old Jan 31, 2021 | 08:51 PM
It's a law that fuel pumps only crap out when the tank is above 3/4.
Old Feb 1, 2021 | 10:34 AM
Moparite's Avatar
Moparite
There is another filter under the "sock".
