Running rich? O2 sensor heater and high voltage codes
Old 02-13-2021, 03:11 PM
DerTruck's Avatar
DerTruck
DerTruck is offline
I am pretty sure they are keyed so you can't switch them
The connectors, yes. But you can stick the sensor in the wrong location.
Probably shouldn't have written "reverse the connections".
Old 02-13-2021, 03:14 PM
2bit's Avatar
2bit
2bit is offline
The other thing I have seen mentioned is the brand of sensor you installed. The aftermarkets don't communicate well with the computer. NTK or Mopar are preferred.
Old 02-13-2021, 06:08 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Lol it happens
Old 02-13-2021, 07:19 PM
01-5.9mag's Avatar
01-5.9mag
01-5.9mag is offline
I put the cheap Bosch ones in. Maybe that’s the problem
Old 02-13-2021, 07:20 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
That's at least part of it.
The following users liked this post:
2bit (02-16-2021)
Old 02-13-2021, 07:58 PM
01-5.9mag's Avatar
01-5.9mag
Okay I will change the sensors and see if it helps. Will update when I do
2bit (02-16-2021)
Quick Reply: Running rich? O2 sensor heater and high voltage codes
