95 1500 5.9 long cranking
Old Feb 19, 2021 | 01:33 PM
mtntrogger's Avatar
mtntrogger
Default 95 1500 5.9 long cranking
Its been a minute since I posted on here and figured it was a good time to ask a question here. I have noticed recently that my truck is cranking an abnormally long time before the engine starts. I replace the plugs annually so I know its not that. I also replaced the fuel pump and starter within the last 2 years, and the battery is almost new. I noticed a similar thread in which @Hey You replied to someone having this issue. He said that on his Ram this was caused by a bad cap and rotor. Im not sure if that could be a possible cause of this problem with my year of truck. I also wondered if it could be ignition timing ?
Thanks for any replies gents !
Old Feb 19, 2021 | 02:11 PM
true blue's Avatar
true blue
Several things to look at...1)does it take long cranks all the time, only certain times like hot or cold?, 2)what's your fuel pressure at the fuel rail?, 3) have you tested the spark at the plugs? Is it weak orange or strong blue? N yes, double check the cap n rotor.
Old Feb 19, 2021 | 02:40 PM
Timing isn't adjustable on these trucks. What brand plugs are in there?? What type?
Old Feb 20, 2021 | 09:30 AM
Moparite's Avatar
Moparite
X2, If you have a aluminum insert cap toss it and get one with brass inserts. They will long out last the aluminum ones.
Old Feb 20, 2021 | 12:41 PM
mtntrogger's Avatar
mtntrogger
Im almost certain they are AC Delco, theres a longshot they are champs
Old Feb 20, 2021 | 12:44 PM
mtntrogger's Avatar
mtntrogger
I will have to pay closer attention, but it seems like I notice it more when the truck is cold. Havent tested pressure at the rail, like I mentioned I replaced the fuel pump pretty recently. I also have not checked the spark at the plugs. All very good ideas though, thank you ! I will report back when I get more data
