Truck not starting
Old Mar 9, 2021 | 09:07 AM
Originally Posted by coilwire
Still working on my no start issue here on a Neon. Checked over everything wiring, new crank and cam sensor. Have voltage at the plug for sensors and ground. Timing belt hasn't broke have looked through inspection cover on timing belt cover and cam is turning. How's the timing on your truck. What ill be checking today on my Neon make sure belt hasn't jumped a tooth or two making the cam and crank sensor out of sync. Being a interference engine on a neon hope haven't bent any valves but then again haven't heard any noise like tapping knocking going on cranking engine could be a good sign tough to say. Maybe chain on your truck jump a tooth being it's a 1997 have a cam sensor? Out of sync with crank sensor could be causing no start from doing more research. Probably good DODGE does this keep you from having major engine damage out of sync cam/crank sensor telling you timing might be off?
This is the 2nd Gen Ram section.... Trucks. We don't have a clue about Neons.....
Old Mar 9, 2021 | 10:28 PM
DerTruck's Avatar
DerTruck
Originally Posted by CrazyCozart
It's got great fuel pressure. I checked the fire again and it's a orange brown. I always thought it should be a strong blue/white. So maybe coil is the problem, what do you all think
Yes the spark should be blue/white. Could be the coil but if you have the means test the coil before replacing it. Plenty of info on the web.
