rear disc conversion
Old 03-21-2021, 04:05 PM
racejunky's Avatar
racejunky
racejunky is offline
Default dash issues
I don't think it will come as a surprise that my dash is crumbling. I'm even having some problems with the actual frame work that everything is mounted to. Is the best way to remedy this finding one in a salvage yard or is there some way to repair what's there? I tried to put this in a different location but I guess I haven't figured out how to navigate that well yet.
Old 03-21-2021, 11:51 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Originally Posted by racejunky
Wow, y'all are way more knowledgeable than I am with this. Where is the transition from 2nd gen to 3rd gen. I assume my "96 is 2nd gen, and how would I determine what the rear end is and what the gear ratio is or would that even matter if I do a complete swap?
3rd gen is 2002 in a 1500 and 2003 in 2500/3500. Since 3rd gen 1500s have cv axles in the front you can't use it. You can tell the gear ratio by a tag on the differential or just pulling the differential cover it will be marked on the ring gear. The rear ends in the 1500s are the same (even today) Chrysler 9.25
Old 03-21-2021, 11:52 PM
MoparFanatic21
if it's just the cover you can buy them from LMC. If the plastic frame is bad, junkyard it is
Old 04-07-2021, 02:58 PM
racejunky's Avatar
racejunky
thanks for all the info I can tell I'm gonna be spending a lot of time at the local salvage yard.
Quick Reply: rear disc conversion
