Alternator Regulator "Delete"? Any ideas?
Old Mar 19, 2021 | 08:26 PM
AlleyCrawler's Avatar
AlleyCrawler
Default Alternator Regulator "Delete"? Any ideas?
Currently in the final phases of replacing an LA 318 with a Magnum 360. It's a bare bones strictly off roading vehicle. One of the last hurdles Im looking at it figuring how to wire up a new magnum alternator to simply charge the battery while its driving. Either all the time or switched on/off.
Anyone have an idea how I can accomplish this? I understand that the magnums regulator may be directly controlled from the PCM but the less electronics I have in this vehicle the better. Essentially its a battery, a fuel pump, a starter, a distributor, and an alternator and thats the extent of electronics in this truck. Its never going to be ran for more than 5-10 minutes at a time as well. I've been looking at the service manuals for these trucks but I cant seem to find anything that would explain how to bypass the system except for in the 1996 Ram manual 8C-6 it shows them grounding out the negative field control terminal to try a test. If it was as simple as running a wire to a switch to ground id be laughing. Fire up the truck, flick on the charging circuit, run it for the 5 minutes i need it, and then shut it off.
Any ideas for this obscure issue?
Old Mar 19, 2021 | 08:35 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can add an external vintage regulator. A quick Google search will bring up how to do it
Old Mar 19, 2021 | 09:56 PM
AlleyCrawler
Thanks bud, I guess it comes down to knowing what to google. I was looking to delete but the answer was the external! And it uses parts I already have kicking around too.
