Thermostat Bleed Valve
Old Mar 24, 2021 | 04:45 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Thermostat Bleed Valve
I can't remember who asked me, but a forum member asked what brand thermostat I had when I told him it had a bleeder valve. So I found out what brand it was Duralast Gold. Here is my thermostat and the picture from the website (I use the app).
Old Mar 24, 2021 | 08:18 PM
Moparite's Avatar
Moparite
There should be a sticky about this, I mentioned it before. Seems someone every other week posts about air in the cooling system that they cant get out.
Old Mar 24, 2021 | 08:32 PM
MoparFanatic21
Sorry Mopar my brain is young but forgetful as in trying to get the property back in shape (one guy taking care of 100s of acres is stressful lol). I didn't forget you just had to wait until I got my thermostat changed
Old Mar 25, 2021 | 11:36 AM
ol' grouch's Avatar
ol' grouch
Well.....that's a jiggle valve, not a bleed valve. Bleed valves are on the block. You'll get better heat and fuel mileage with a 195 degree thermostat. Right now, your engine is in open loop mode to warm up.
Old Mar 25, 2021 | 04:45 PM
MoparFanatic21
My mistake on the terminology and it does allow air to pass the thermostat.
Old Mar 25, 2021 | 07:33 PM
ol' grouch's Avatar
ol' grouch
Don't worry about it. I still drill a 1/64 hole if there isn't one already. It prevents air lock.
Old Mar 25, 2021 | 09:52 PM
MoparFanatic21
​​​​​​ Absolutely! I drill a 1/8th hole
Old Mar 26, 2021 | 09:08 AM
ol' grouch's Avatar
ol' grouch
In the late 1930's, Plymouth cars started overheating. Chrysler had changed suppliers and the NEW thermostats were built to close specifications. The old ones leaked. The new ones didn't and air would build up and create an air block. When I finally opened, water was slamming into hot metal and gushing enough to blow radiator caps off.
Old Mar 26, 2021 | 09:32 AM
MoparFanatic21
Dang lol
Old Mar 28, 2021 | 10:36 AM
MoparFanatic21
​​​​​​ Also I did upgrade to a 195 as my truck was complaining about the 180 plus the heat wasn't that great. I was just showing the old one because I put the new one in with no pictures but confirmed it had the jiggle valve
