I have a 1999 dodge ram 1500 4x4 5.2l, my left upper ball joint seems to be worn out on the axle assembly, I have a dana M44F with a 3.55 gear ratio, the 8th vin is y, can I use the front axle assembly with the 8th letter being a z if the gear ratio are the same ?
