Rear shock orientation question
Hey yall it's a happy day and I got a set of bilsteins 5100 for the truck.
so I've seen people do it both ways but which is the right way to install these? Is the boot side supposed to face down or up ? I would think that it would face up but I've seen videos of doing both and one guy said having the boot side facing down is " upside down" . Any insight would be great.
the Monroe shocks don't have a boot on them like the bilstein but yes. I think I'm going to have the boot pointed up like how the new fronts are. Just want to do it right once.
The shocks do indeed have an orientation, there are differences between compression, and rebound damping....... If you aren't sure, may wanna call the manufacturer, and ask them which way is correct.
Fair enough
Well compression is compression regardless of the orientation of the shock
. What makes a difference though is if the shocks are twin-tube or mono-tube designs. Mono-tube shocks work in any position, twin tubes generally not because gas ends up in the inner compression tube.
Edit: Bilstein 5100 are mono-tube so either orientation works.
. What makes a difference though is if the shocks are twin-tube or mono-tube designs. Mono-tube shocks work in any position, twin tubes generally not because gas ends up in the inner compression tube.Edit: Bilstein 5100 are mono-tube so either orientation works.
Thank you for your knowledge sir. I did contact bilstein and they said that it's made for boot facing up so that's what I'll go with . Thanks for input everyone I guess I should of just called them first lol
Trending Topics
Under the boot is a single rod. On unbooted shocks, this goes to the top. The boot is just there to keep grit and dirt off the upper shaft. Well, it looks better too. Anyway, boot up and the dampers will work best and longest.
Shock absorber is a misnomer. They are actually rebound dampers. The shock is absorbed by the tires and springs. The damper stops those from bouncing.
