2001 3500 5.9 diesel rpm surging/fluttering
Old Apr 17, 2021 | 07:35 PM
2RamsJake's Avatar
2RamsJake
Default 2001 3500 5.9 diesel rpm surging/fluttering
1450-1500 rpm consistently fluctuations mimicking fuel starving then catching, over and over. With more throttle it smooths out. No codes present.
Old Apr 17, 2021 | 08:07 PM
Vacuum leak?
Old Apr 17, 2021 | 08:42 PM
2RamsJake's Avatar
2RamsJake
Thanks, but double checked and all good 👍.
Old Apr 17, 2021 | 11:18 PM
Keith_L's Avatar
Keith_L
Our '02 does something similar when the VP44 relay gets flakey but it also falls on its face and has no power.
You're getting no other driveability issues?
Old Apr 17, 2021 | 11:24 PM
2RamsJake's Avatar
2RamsJake
It also cuts in and out under load at highway speeds like the fuel is cutting off and on.
Old Apr 18, 2021 | 12:53 AM
Keith_L's Avatar
Keith_L
Well typically the relay will set a "lost comm with VP44" code, but for giggles you could swap it with something like the horn relay and see if anything changes
Old Apr 18, 2021 | 05:16 AM
2RamsJake's Avatar
2RamsJake
Tried that, thanks, no changes.
Old Apr 18, 2021 | 05:57 PM
Mike Holmen's Avatar
Mike Holmen
Have you measured the pressure at the injection pump? You need at least 12+psi. How stock is your truck? Usually if the VP is on its way out it will start setting of codes in the ecm. You have any fuel leaking at the injectors? You done any recent repairs?
