Transfer case
Old Apr 20, 2021 | 03:51 AM
TonyValenica's Avatar
TonyValenica
Default Transfer case
So I have a 96 Dodge Ram 1500 5.2 v8 and my transfer case cracked. I have someone willing to sell me a transfer case that they no longer used but it’s a 241 dhd from a Ram 2500 5.9 v8 I’m wondering if it’d fit. If anyone can confirm this before I purchase that’d be great
Old Apr 20, 2021 | 06:45 AM
What year is the donor t-case from?
Old Apr 20, 2021 | 11:39 AM
TonyValenica
it’s from a 96 but the dude wrote on the t case that it’s from a 2500 5.9 L
Old Apr 20, 2021 | 06:21 PM
It will physically bolt to your trans, but, the case is longer than the stocker. So, you will need to shorten the rear driveshaft for that one.
Old Apr 20, 2021 | 09:02 PM
TonyValenica
the guy is also willing to give me the drive shaft as well so would that work ?
Old Apr 20, 2021 | 09:25 PM
I think the U-joint at the rear of the shaft will be a different size on the 2500.... Could get a hybrid joint, likely cheaper than having your shaft cut down.
For as many of the 231 cases that are out there, you would think they would be easier to find..... Of course, you can only use the case from a truck that is 97 or older. Newer trucks won't have the provision for the VSS in the tailshaft.
