ram 1500 5.2l not starting
Old Apr 21, 2021 | 05:44 PM
haydenstimmetz1's Avatar
haydenstimmetz1
Default ram 1500 5.2l not starting
i have a 96 1500 5.2l and i replaced the coil,plugs,wires, and distributor the other day. and it started for about 10-15 seconds and then died and now it won’t start. it’ll crank but won’t turn over. and i’m getting spark, air, fuel, and the timing is correct. and i replaced the crank sensor but that didn’t solve the problem. help
Old Apr 21, 2021 | 06:34 PM
ol' grouch's Avatar
ol' grouch
First off, cranking and turning over are the same thing. You mean it will crank but not start, correct? Shoot a little starting fluid into the throttle plate on top of the engine. If it runs a bit then dies, you aren't getting fuel. If it still doesn't start, you have an electrical issue. Give that a try and then get back with us and we'll see what we can figure out.
Old Apr 21, 2021 | 06:47 PM
DerTruck's Avatar
DerTruck
Your post says distributor but I assume you mean the cap ? If you had the distributor out that could be an issue.
Old Aug 29, 2025 | 12:27 PM
mrelijahgardner's Avatar
mrelijahgardner
deleted
Old Aug 29, 2025 | 01:19 PM
AtomicDog's Avatar
AtomicDog
Question
Was the engine running before you made all of the changes you've listed? Lastly, did you change the complete distributor or just the distributor cap & rotor?
Old Aug 29, 2025 | 05:02 PM
Four year old thread.....
Old Aug 29, 2025 | 05:51 PM
Moparite's Avatar
Moparite
mrelijahgardner only has 2 posts, The one here he deleted. Probably because it's old thread. He then started his own thread so he should be commended. Now if we can get the others to be more like him instead of posting on years old threads.
Old Aug 29, 2025 | 06:47 PM
AtomicDog's Avatar
AtomicDog
Post
Duh! I missed the date. Sorry...
