My transmission to transfer case flange broke..
I will jack it up and see if that helps. Those bolts are off because I was attempting to just disconnect it everywhere I could in an attempt to get it off, but understanding that it was not going to help me at all now lol .
Busy as hell right now but gonna get back to it soon. I guess I cant really investigate the transmission once the drive shafts are off?
Honestly exhaust manifold leak is kind of putting it lightly.. I'm not positive that's what caused this though. Like hey you suggested probably time for a transmission swap.
Ijs
Once you have the transfer case out of the truck, it would be good to see photos of the front of the transfer case and photos of the front driveshaft and the rear driveshaft. I'm wondering if something caused your transfer case to violently buck to cause the carnage at the rear of your transmission, like a binding U-joint in the front driveshaft.
I've been under my 98 twice in the past 4 months replacing cracked rearcase halves. My pain ain't like your pain but I feel ya man. Btw I'll listen if anyone wants to advise why I've lost two rear transfer case halves. They crack open and didn't have load on the truck, the u joints are recent. I've pulled the front shaft for the time being, as if it might be shaking the transfer case. Scratching muh head on the why.
Thanks
If you carefully lower the skid plate. What's left of the transfer case will slide forward off of the driveshaft.
Thanks
Thanks
Thanks
Thanks
Just today getting back underneath. Trying to get the skid plate off to try this idea. T case seems pretty damn heavy, hoping for the best lol.
I almost got it to slide off in its current orientation. I think so anyways. Assuming that shaft that goes from the back of tcase to driveshaft is like 7 inches or so. Need another inch. Tried jacking t case up but still not enough room.
Meanwhile ive been hammering on rear drive shaft connection to differential. No avail, bitch is hanging on tight. I figure once I get the t case down I can pull it off better...
Unbolt the driveshaft from the rear diff, likely have to pry the u-joint out of the yoke. Then, the shaft *should* just pull out of the t-case. If it doesn't, two things. 1. Now you know why the flange broke...... and 2. Need to find out why it's jammed up.
At this point, you *should* be able to just pull the t-case off the shaft. If it's stuck on there though..... need to figger out why.
I can almost just pull the t case off but now the front drive shaft is hitting the frame, blocking me. I would just take the front drive shaft off now that its lower, but it's eben more of a bitch for some of the bolts with it pointed up like that
