My dodge
Old May 31, 2021 | 07:33 PM
randy_lee's Avatar
randy_lee
Default My dodge
I’ve got a 2001 Dodge ram sport 5.2 L I added blue devil to the radiator to stop the leak well I ran it I’ll idled idled it for 45 minutes then let it cool for an hour when it started up nothing Man change fuel pump fuel relay fuse odometer when you turn the key on it may 6tones for flashes on the odometerAnd says no bus
Old Jun 1, 2021 | 06:59 AM
The two events are unrelated.
No bus means the cluster isn't communicating with the PCM. If the truck won't start... it's likely one of the sensors on the 5 volt bus has gone belly up, and taken the whole thing down. May also be a failed PCM. If you have a scanner, plug it in, see if it will talk to the PCM.
Welcome to DF! Moving this to second gen ram section for ya.
