Transmission slip
Old Jun 11, 2021 | 10:44 AM
studders's Avatar
studders
Default Transmission slip
Hello. I have a 1999 Dodge Ram 1500 4x4 5.9L. Seems when I go up hills or grades it acts like it doesn’t want to shift. Rpms go high. When I take the overdrive off it seems to shift and do fine. Been doing that for a bit (taking overdrive off) when I come to to a hill just to make it up. I have a lot of hills where I live and around. Is this the transmission going or maybe something electrical or other issues.
also what could be causing he seatbelts to lock while we are driving. They would be fine for a bit then seem both seats lock and we have to take them off before they get to tight. Turn the engine off for a bit and I guess it resets itself and they are fine for the next ride. Thanks
Old Jun 11, 2021 | 11:00 AM
How many miles on the truck? Has the plenum been fixed? Any engine codes??
Old Jun 11, 2021 | 01:55 PM
studders's Avatar
studders
no engine codes. Roughly 125,000 miles. Give it take a few. Can’t remember off the top of my head. I can look when I get home. I replaced the plenum gasket about 7 years ago
Old Jun 11, 2021 | 02:48 PM
Last time fluid/filter were changed? I might be tempted to do the governor pressure stuff as well as the output speed sensor...... (not to mention the band adjustment..... )
Old Jun 12, 2021 | 07:00 PM
studders's Avatar
studders
filter/fluid was changed about 11 years ago. Couldn’t tell you how many miles were out on it since then. The last 3-4 years had only been used as needed to haul or pull something as it is not my daily driver.
Old Jun 12, 2021 | 07:02 PM
Yeah, do the fluid/filter/governor stuff. I am reasonably sure that should deal with it. Adjust the bands while you are in there.
Old Jun 13, 2021 | 10:01 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The seat belt issue is probably the seat belt module. It's under the center seat in the front, they are known to go bad.
