Bent push rod, is it a problem?
Old Jun 11, 2021 | 03:50 PM
Steven Jones's Avatar
Steven Jones
Default Bent push rod, is it a problem?
My buddy and i recently changed the plenum, he mainly did all the work because my mechanical knowledge is limited and im just getting started. I however noticed i had a bent pushrod. But it doesnt seem to be affecting anything. There are no misfires. I was wondering if this is a serious problem or will be down the line?
i have a 97 ram 1500 5.9 with 275 k miles
Old Jun 11, 2021 | 04:24 PM
AtomicDog's Avatar
AtomicDog
If the pushrod is bent, the valve being controlled by it is likely not opening as far as it would normally. While you're in there, its advisable to replace it.
Old Jun 11, 2021 | 06:17 PM
ol' grouch's Avatar
ol' grouch
One has to wonder why it is bent. Keep in mind, the push rod is designed to put the strength along the length of the rod. Instead of the stress linear, you have lateral stress. Try opening a valve against the spring. It's not easy. Each time the cam lobe rises, you have a little more pressure to bend the rod more. Think of a pencil. Press straight down and it can take a lot of pressure. At an angle, it will snap. It will eventually bend more until the valve doesn't open at all. I'd check all of them. Put them on a flat surface and roll them. I'll bet you just noticed the worst one of the bunch. Myself, I'd replace them all.
Old Jun 12, 2021 | 01:31 PM
HD Kowboi's Avatar
HD Kowboi
Maybe add some 1.7 roller rockers while you're in there.
Old Jun 12, 2021 | 01:36 PM
I see that you are going to fit right in here.
Old Jun 12, 2021 | 09:45 PM
HD Kowboi's Avatar
HD Kowboi
Lol, yup lots of good stuff here
Old Jun 13, 2021 | 10:02 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
For my 408 Hughes recommended 1.6 which is what I got. Should have went with my gut and got the 1.7
Old Jun 13, 2021 | 10:11 AM
If you were changing the cam anyway.... I could see doing the rockers just to get the "roller" part of it, but, if you wanted more lift/duration, stick with the 1.6 ratio, and get a bigger cam.
Old Jun 13, 2021 | 10:51 AM
MoparFanatic21
I know I'll regret it later
Old Jun 14, 2021 | 07:19 AM
HD Kowboi's Avatar
HD Kowboi
Getting back to the main focus of the post, I would be concerned first of all as to why it was bent in the first place.
