2001 ram 3.9 2wd reverse not working.
Old Jun 29, 2021 | 08:46 AM
clorbag's Avatar
clorbag
Unhappy 2001 ram 3.9 2wd reverse not working.
just got a 2001 ram with a 3.9 and is 2wd automatic. issue is when i put it in reverse i can feel it engage, but when i give it a bit of gas it feels like it slips out and acts like its in neutral.
sometimes when i shift into reverse it shakes hard like its trying to grab? all the drive gears work fine, it shifts good through all 4 gears smoothly but only reverse is having an issue.
i did some research and i will adjust the reverse band sometime this week when it stops raining. while i have the pan off is there anything else i should replace? i am putting a new filter gasket and a
pan with a drain on it. also what is the correct band adjustment procedure? 72 inch lbs tight and 4 full turns off? anyway thanks for reading this rant. any and all help is appreciated.
also i think it has the 42re transmission but does anyone know for sure? first ram.
Old Jun 29, 2021 | 08:52 AM
Which trans is it?
Old Jun 29, 2021 | 09:00 AM
clorbag's Avatar
clorbag
Which trans is it?
I think it's the 42re
Old Jun 29, 2021 | 09:05 AM
You can grab the service manual for your truck from here. Specs for band adjustment should be in there.
Welcome to DF!
Old Jun 29, 2021 | 11:40 AM
clorbag's Avatar
clorbag
Welcome to DF!
thanks for the service manual, anything else you guys recommend while i have the pan and the filter off?
Old Jun 29, 2021 | 04:22 PM
Just fluid and filter, and bands (there are two) at this point. See if that solves your issues before spending any other money on it.
Old Jun 29, 2021 | 04:26 PM
clorbag's Avatar
clorbag
thanks that's the plan! The engine runs good, Id hate to need a new trans...... I'm trying to get this truck running well so I can get out of car payments. Thabks for the help.
