Front Dana 44
Old Jul 7, 2021 | 08:41 PM
SATIN5.9RAM's Avatar
SATIN5.9RAM
Default Front Dana 44
So I have a passenger side leak. What is there for bearings in this axle cuz I have a wobble too. Seems like passenger side. Is it just the diff left and right bearings? And how many seals?
thanks from the axle newbie
Old Jul 7, 2021 | 09:38 PM
There is a seal that you can get to thru the cad. With the axle out, you can replace that. Bearings are just the unit bearing the wheels bolt to.
Old Jul 8, 2021 | 01:15 AM
AtomicDog's Avatar
AtomicDog
There are carrier bearings inside the differential, however, those usually don't have issues unless the differential has been seriously low on oil or some other sort of serious abuse.
Old Jul 8, 2021 | 11:34 AM
SATIN5.9RAM
ok so would that seal being worn cause a vibration at all? Does it help center the axle at all?
Old Jul 8, 2021 | 12:14 PM
Nope. Just a seal. Driveline vibrations, I generally have a hard look at u-joints, or tire balance first.
