Transmission anti back flow valve
Old Jul 8, 2021 | 09:37 AM
ksbowman's Avatar
ksbowman
Default Transmission anti back flow valve
Just put in a new auto trans in my 01. I had to install a new trans cooler to have warranty on trans. I want to use the anti backflow valve but can't find a male nipple connector to screw on the existing backflow fitting. Any body know where I can get it? Dodge says they don't know.
Old Jul 8, 2021 | 12:15 PM
Are you bypassing the in-radiator cooler?
Old Jul 8, 2021 | 10:30 PM
ksbowman's Avatar
ksbowman
Yes, The supplier of the transmission supplied a new larger cooler and I need to tie into a 3/8" rubber hose with the anti backflow valve. I've been to Dodge and all the auto supply store chains in the K.C. area and no one has had a fitting to hook up to the Valve or has given me any info on where to get one. Dodge says it is not a fitting used by them so they can't help me.
Old Jul 8, 2021 | 10:33 PM
Just put the rubber hose directly on to the cooler line for the trans. Check valve is notorious for clogging up, and smoking transmissions anyway.
