Engine runs hard on a 1994 Ram 1500 5.2
Old Jul 14, 2021 | 10:25 AM
  #21
Krossome's Avatar
Krossome
Okay well in that case then it must be working because it fires up. You cant hear the pump though. I usually would hear it kick on or hear it while it was running but it’s completely silent now
Old Jul 14, 2021 | 12:22 PM
  #22
Think I would be testing pressure with the engine running, and see what happens when you step on the gas a bit.
Old Jul 17, 2021 | 02:15 AM
  #23
Krossome's Avatar
Krossome
So I haven’t gotten a chance to check the pressure while running for a while yet but if it’s in park or neutral the throttle response is great and the pressure has to be too because it’ll rev right up just fine but if I put it in gear, hitting the gas does absolutely nothing. When dropped in gear it starts to run really rough to the point of barely running and hitting the gas doesn’t do anything. It won’t even idle forward or back if I take my foot off the brake while in gear.
