96 Ram 1500 - mystery electrical plug
Old Jul 30, 2021 | 04:36 PM
mikelund's Avatar
mikelund
Default 96 Ram 1500 - mystery electrical plug
Just got this truck and unfortunately the previous owner is no longer around to ask questions so here I am. I found the unconnected plug right above the AC dryer and I’m curious what it’s for. I posted a picture to go along with it. Any info is great, thanks!
Old Jul 30, 2021 | 05:21 PM
DerTruck's Avatar
DerTruck
That's the old school diag plug but it's weird to see this on a 96 which is OBD2.
Old Jul 31, 2021 | 06:26 AM
Moparite's Avatar
Moparite
Have a look in the factory service manual, In the back there are diagrams of every plug used.
Old Jul 31, 2021 | 08:31 AM
mikelund's Avatar
mikelund
I found on the epa.gov website that it was federal mandate that all vehicles manufactured after 1/1/96 had to be OBD2 but my truck was manufactured in May 95 so that probably explains why it’d be OBD1 still
Old Jul 31, 2021 | 11:32 AM
Does you PCM have one large plug, or three smaller ones?
Old Jul 31, 2021 | 12:09 PM
AtomicDog's Avatar
AtomicDog
I have that same plug in the same place on my '96 Ram 2500 4x4 5.9 magnum engine truck. I was told by a former Dodge mechanic that it was the old style OBD1 plug even though I have the OBD2 plug under the dash. The production date of my truck is 11-1995.
Old Aug 1, 2021 | 12:26 PM
mikelund's Avatar
mikelund
three smaller ones
Old Aug 1, 2021 | 12:56 PM
Originally Posted by mikelund
three smaller ones
Ok, that's OBDII..... Weird. Wonder if the old connector works as well....
Old Aug 1, 2021 | 01:27 PM
AtomicDog's Avatar
AtomicDog
I was hoping that it worked, but when I tried to connect the Snap-On MT2500, the scanner wants to connect to the OBD2 port under the dash when I use the VIN information to identify the truck, as I had hoped to pull ABS information, but the scanner wasn't able to access ABS related data at least through the OBD2 port. I might have to try telling the scanner that the truck is a 1995 and it might want to connect via the other OBD1 port.
Old Aug 1, 2021 | 02:20 PM
J D GA's Avatar
J D GA
Default Service Manual link
For my current project, "diagrams of every plug used" might be helpful, as well as other electrical components (i.e. TCM, DRL module, the 26pin J/C 1 & 16pin J/C 2 in the PDC). I've seen references here to a service manual link in many other posts here but when I tap it, downloading starts on a 2,889 page PDF. I know such a manual would be great to have and I would be grateful to access it. There's no telling how long it will take to finish via 1-bar on 4GLTE soooo...... I guess the best I can do about that is public WiFi at Monday night's poker table.
For my current project, I'm making a relay's wiring harness for DRL, which my 01 1500 Laramie 5.9 (seemingly) doesn't have. I'm about to write a separate post for that.
Thanks y'all.
