Speedometer Doesn't Work!
Old Aug 30, 2021 | 11:24 PM
Joe Wood's Avatar
Joe Wood
Default Speedometer Doesn't Work!
OK so my '95 1500 Ram's speedometer stopped working! I've never faced this before, so where can I start troubleshooting it? Hopefully I don't have to tear the dash apart!
Old Aug 30, 2021 | 11:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is your check engine lamp on? If it is scan for code. You may have a bad output sensor or wires going to the sensor. I don't believe the 1995 ram trucks had a speedometer cable.
Old Aug 31, 2021 | 09:35 AM
AtomicDog's Avatar
AtomicDog
If this is a 4WD truck, check the speed sensor and wiring on the transfer case. There is also a pinion gear turning the sensor. On a 2WD truck, that speed sensor and wiring should be on the transmission extension housing. You can also download the service manual for that year truck from here (https://dodgeforum.com/forum/2nd-gen...e-manuals.html) and it should have a troubleshooting procedure.
Old Aug 31, 2021 | 12:24 PM
Joe Wood's Avatar
Joe Wood
no light on, and this is a 2wd 1500.
I'll check out that manual!
Old Sep 3, 2021 | 12:37 PM
Joe Wood's Avatar
Joe Wood
OK, I haven't done any troubleshooting yet but,
the speedometer is working agin, does that give anyone a clue of what's happeing?
Old Sep 3, 2021 | 06:36 PM
AtomicDog's Avatar
AtomicDog
A loose wire/connection or sensor about to go bad? Keep an eye on it and follow the troubleshooting information in the service manual.
Old Sep 5, 2021 | 01:04 PM
Joe Wood's Avatar
Joe Wood
Thanks Dog!
