Magnum 5.9l Distributor Placement
Old Oct 13, 2021 | 12:42 PM
BClark_35's Avatar
BClark_35
Default Magnum 5.9l Distributor Placement
So I am a bit confused on where the distributor should be pointing. I have no messed with the placement of the rotor but not thinking I did move the base of the distributor around. I currently have the engine at top dead center on cyl 1. The rotor is facing cyl. 8. I haven't messed with that so that's what the factory had it at. My question is where should the distributor be in relation to the rotor? Should the cyl 1 mark on the distributor align with the tip of the rotor? Here is a picture.
Old Oct 13, 2021 | 12:57 PM
With #1 in firing position, (top dead center, both valves fully closed) the rotor points at the mark on the distributor.
Old Oct 13, 2021 | 01:08 PM
BClark_35's Avatar
BClark_35
The issue is the that I'm an idiot and moved the base of the distributor so it's all messed up. So now do I just move the mark on the distributor so that it lines up with the rotor?
Old Oct 13, 2021 | 07:37 PM
That would likely work.
Old Oct 18, 2021 | 10:54 PM
95RAM360's Avatar
95RAM360
Now you say you moved base, are you referring to a minor twist of distributor or did the gears un mesh? If they didn’t unmesh then you should be fine, as long as engine is at #1 TDC and the rotor point to the mark on sensor plate. The clamp bolt should make it pretty much stationary, I had to pull my distributor a couple weeks about because both cap bolts broke, all I did was ensure tdc/ mark on plate, the clamp bolt prevented any twist movement, so I’m led to believe your bolt may not be on correct? The clamp portion on mine looked like a C and there’s a slot on distributor that that fits into in turn locking distributor into stationary position
Old Oct 18, 2021 | 10:56 PM
BClark_35's Avatar
BClark_35
Well I've got it now. But some everything is getting taken apart so I can rebuild it I'll have to do it again. Just wanted to make sure I had the right idea on what was required for it to be correct. Pretty sure I got it
