2001 ram major ?????
Old Oct 20, 2021 | 04:39 PM
Rppalace's Avatar
Rppalace
Default 2001 ram major ?????
Hi again everyone . I've been messing with this for over a week now . the truck is a 01 ram 1500 2 wheel 5.9 L auto . I have a p0601 code on the pcm . but it is running so bad it won't move and it is dying . like it's jumped time or something . when it first happened I had another code also but I can't remember what it was and the ole lady threw the paper away it was wrote on . but I believe it was a random misfire or something like that . it all had me thinking that the pcm is bad . but now im not sure . please help !!!!
Old Oct 20, 2021 | 07:36 PM
The P0601 is a fatal error. Memory checksum error. The PCM is toast. None of the other codes are relevant, as the PCM itself is bad.
Old Oct 20, 2021 | 08:20 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I have a 2001 Chrysler that had the code for internal memory error and it runs fine. But as HeyYou said the computer is toast
Old Oct 20, 2021 | 08:34 PM
Rppalace's Avatar
Rppalace
It's been running fine with that code on it for a few months now .all of a sudden it started running super rough and dying . it is also making alot of noises from the lower rear of the engine . could the timing have jumped ? It has 332000 miles on it .
Old Oct 20, 2021 | 08:47 PM
With that many miles on it, it's entirely possible.
See if you can find a junkyard PCM, just needs to be the correct year, engine and trans combo. See if it runs any better.
Old Oct 20, 2021 | 08:57 PM
Rppalace's Avatar
Rppalace
Thanks I'll try to find one . is there a way to check the timing without disassembling ?
Old Oct 21, 2021 | 06:26 AM
Turn the engine so #1 is in firing position, see where the rotor is pointing. (distributor.)
Old Oct 21, 2021 | 06:45 AM
HD Kowboi's Avatar
HD Kowboi
332000 miles is pretty impressive!
Old Oct 27, 2021 | 04:21 PM
Rppalace's Avatar
Rppalace
Default Update
Ok y'all . first I want to start with thank you everyone for your help . I bought a new pcm . it's running a lil better but I have a new code now . 1391 . which is a crankshaft or camshaft malfunction or timing chain jumped . so I pulled the dist cap off and got it up to tdc and the rotor button is pointing towards the passenger side . straight 90 degrees. I don't see any mark on the plate . but should it be on the number1 wire out the cap ?
Old Oct 27, 2021 | 06:06 PM
Rppalace's Avatar
Rppalace
Default Flexplate
Hello again . I put a new flexplate on this truck about 8 months ago . I just noticed it's broke again . would that make it run all rough and cut off when you put it in gear ??
