Rear diff bearings
So I basically ****ed my rear diff bearings (English is not my main language but I think the are called bearing I mean the 2 whit the bolts that holds the diff in place) but the problem is I have a 2001 5.9 sport off-road edition whit a towing pack is it correct that I have the 4.10 ratio? And if not what brand of bearing should I order and meanly where can I get the best parts in the us? I normally use rockauto.com.
thanks in advance for anyone that can help
The differential has carrier bearings and pinion bearings. Do you know which ones you need? The carrier bearings are on each side of the center section of the rear and the pinion bearings are behind the U-joint inside the rear.
Randy's Ring and Pinion would be a great source, OP
SKFJLM704610{#05072506AA, 3723148}RaceInfo
SKFJLM704649{#05072506AA, 3723149}In
I would change the pinion bearings and seal also
SKF BR52 {Click Info Button for Alternate/OEM Part Numbers} Info
Rear Outer; 9.25" Ring G
SKF M804049 {Click Info Button for Alternate/OEM Part Numbers} Info
Rear Inner; 9.25"
SKF M804010 {Click Info Button for Alternate/OEM Part Numbers} Race Info
Rear Inner; 9.25" Ring Gear
SKF 18852 {Click Info Button for Alternate/OEM Part Numbers} Info
Rear; 9.25" Ring Gear
Rear Inner; 9.25"
