OBD1 converted to OBD2
Old Nov 17, 2021 | 06:46 PM
ThatRedRam's Avatar
ThatRedRam
those are all the same arent they. lmao
Old Nov 17, 2021 | 06:58 PM
Grab the PDC from under the hood as well. (likely you will need it....)
Engine harness, PCM, interior harness for the dash. (which will likely be everything inside as well.... dome lights, etc....) Probably some other stuff that you will discover as you go along.... Does your truck have 4WAL, or RWAL?
Old Nov 17, 2021 | 07:00 PM
ThatRedRam's Avatar
ThatRedRam
4wal ..
Old Nov 17, 2021 | 07:03 PM
Originally Posted by ThatRedRam
4wal ..
That may complicate things....... I don't know if anything changed on that... it's entirely possible nothing did.... Take a careful look at the connectors for the controller, see if they look like yours. Might wanna compare the pinouts at the controller end between the years as well.
Old Nov 17, 2021 | 07:05 PM
ThatRedRam's Avatar
ThatRedRam
i have this wiring bull**** might just say **** it and going to a old style 360 and do away with all the wiring lmao. Thats last resort tho but im having a hard time finding a harness for 5.9 magnum only seeing 5.9 cummins
Old Nov 17, 2021 | 07:07 PM
Harness for the 5.2 will be exactly the same.
Old Nov 17, 2021 | 07:08 PM
ThatRedRam's Avatar
ThatRedRam
the motor harness and dash harness will be same as 5.2?
Old Nov 17, 2021 | 07:10 PM
Yep, 5.2 and 5.9 used the exact same harness. (both gas engines. Der diesel is radically different. )
