No heat just cold air
So I just got around to replacing that old busted dash finally and my heat hasnt worked for a long while
change the heater core while changing the dash had to pull the carpet and replace it too cause coolant had leak through the cab from thebad heater core
everything is back together and I still have no heat at all put my hand up agaisnt the heater core its definitely getting hot thermostat was replaced about two years ago and the AC has always worked anything yall think i overlooked?
did you burp the system? Thermostats are $10 I’d try one. Do the hoses feel hot into heater core? Is it overheating?
