Tuners for 1996
Old Nov 24, 2021 | 10:39 PM
96albertaram's Avatar
96albertaram
It's one bolt, pull the vss out of the tailhousing, swap the gear, stuff it back in. It needs to be properly indexed though, there are markings on the VSS housing, and an index mark on the tailhousing. I think the markings on the VSS, or actually gear tooth count.
I just watched a you tube video on a jeep one very similar thank you. Now to find the right one
Old Nov 24, 2021 | 10:40 PM
96albertaram
Originally Posted by AtomicDog
I went by the chart in the link I provided in my last post. That worked well for me and the truck's speedometer readings matched up with my GPS speed readouts.
Changing the speedometer pinion gear is pretty easy as long as the hold-down bolt comes off easy. I had no issue with the transfer case that's in my truck with removing the bolt. I did soak it with PB Blaster before trying to remove it. The spare transfer case that I picked up in Maryland had the bolt broke off in the transfer case and I'm still trying to remove it. Tried numerous times welding a nut onto the broken bolt and still can't get it out. It seems to be oxidized in-place due to the dissimilar metal issue.
Soaking it in pb blaster is a good idea. It's probably never been out before on mine.
