ASD issues
Old Dec 2, 2021 | 07:08 PM
jrwhite1's Avatar
jrwhite1
Default ASD issues
I have a 96 Ram 1500 5.2l, I have replace ECM, Coil, Distributor, Crank sensor, and ignition switch. It will run about a hour then shuts down, and won't restart until it sits awhile. Then it will restart and run about a hour. I discovered if I replace then ASD relay it will restart and run for about a hour. Can anyone give idea where to begin to look to what is causing the relay to shut down?
Old Dec 2, 2021 | 09:24 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
When it won't start need to see what is missing fuel or spark. If you didn't use Mopar sensors that could be your problem.
Old Dec 2, 2021 | 09:35 PM
jrwhite1's Avatar
jrwhite1
Missing spark, when I replaced relay starts right up
Old Dec 2, 2021 | 11:05 PM
DerTruck's Avatar
DerTruck
When something stops working and recovers after a while it's often a temperature related issue. Does the relay or one of its pins feel warm when the problem occurs ? Can you reuse a previously removed relay after an hour or so ?
Old Dec 3, 2021 | 05:41 AM
jrwhite1's Avatar
jrwhite1
The whole relay is hot, yes most of time I can reuse the relay after it cools.
Old Dec 3, 2021 | 10:11 AM
Check all connections for the relay, at both ends. I suspect a poor ground, causing it to heat up.
