360 Cam
Old Nov 18, 2021 | 10:03 PM
ThatRedRam's Avatar
ThatRedRam
Default 360 Cam
I have a 1995 Dodge ram 1500 4x4 auto that im currently building a 360 5.9 for and im wanting to put a good sized cam in it that you will be able to hear but im not wanting to change the heads a whole bunch because they have already been machined and built. So does anybody know of a good cam that i could run that youll hear a little chop chop to
Old Nov 18, 2021 | 10:04 PM
ThatRedRam's Avatar
ThatRedRam
More choppy= better
Old Nov 19, 2021 | 03:25 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You are limited because of OBD1 not tuning available
Old Nov 19, 2021 | 09:09 AM
If you are planning on staying with the fuel injection, that is going to severely limit your cam choices.
Old Nov 19, 2021 | 09:38 AM
ThatRedRam's Avatar
ThatRedRam
I planned on swapping to OBD2 and also is there a way to do away with fuel injection on a fuel injected 360
Old Nov 19, 2021 | 09:51 AM
MoparFanatic21
Yep, carb intake for a magnum
Old Nov 19, 2021 | 10:00 AM
ThatRedRam's Avatar
ThatRedRam
Sense I’m doing away with computer on motor then how will the automatic trans react to it
Old Nov 19, 2021 | 10:10 AM
On yours, the computer only controls TCC, and O/D. You can set up a series of switches to handle those duties though. So, no computer required.
Old Nov 19, 2021 | 10:26 AM
ThatRedRam's Avatar
ThatRedRam
how would I wire a switch to TCC like how would I know when it needs to be on and off
Old Nov 19, 2021 | 10:28 AM
Use pressure switches screwed into the test ports on the trans. Then you just don't have to worry about it. Can wire a switch to disable overdrive though.
