Wild idle issue
Old Dec 8, 2021 | 03:06 PM
Mikewall's Avatar
Mikewall
Default Wild idle issue
I have a 2001 Dodge ram 1500 with the 5.2 V8 and the problem is some days I can crank it and it will idle about 2500 rpm and other days I can crank it and it will idle about 700 rpm and when it idles low it hesitates and stalls bad acts like it won't accept any acceleration until mashed almost to the floor I've changed the IAC valve and the TPS but no luck
Old Dec 8, 2021 | 03:11 PM
Getting any codes?
Normal idle is around 650-700..... How is your fuel pressure?
Old Dec 8, 2021 | 03:15 PM
Mikewall's Avatar
Mikewall
Default Wild idle
I just changed the fuel pump about a month ago but haven't put a fuel test on it that's my next step and I haven't had a chance to get it on a handheld yet
Old Dec 8, 2021 | 03:18 PM
What brand pump did you put in?
Old Dec 8, 2021 | 03:19 PM
Mikewall's Avatar
Mikewall
Default Wild idle
Honestly I don't remember i ordered it from rock Auto
Old Dec 8, 2021 | 03:21 PM
Mikewall's Avatar
Mikewall
Default Wild idle
It was doing this before the pump went out I just replaced it to try to get it back on the road bc it's my way back and forth
Old Dec 8, 2021 | 03:23 PM
Is the check engine lite on?
Old Dec 8, 2021 | 03:25 PM
Mikewall's Avatar
Mikewall
Default Wild idle
Yes it is
Old Dec 8, 2021 | 03:39 PM
Mikewall's Avatar
Mikewall
Default Wild idle
And also when accelerating it has a sucking noise like it's pulling to much air through the throttle body I've checked all vacuum lines that I can get to
Old Dec 8, 2021 | 03:47 PM
One of your local parts stores should be able to read codes for you. Need to know what is upsetting the computer. Otherwise, we are just guessing.
