So done:
Old Dec 25, 2021 | 08:06 PM
Tenacious C's Avatar
Tenacious C
Default So done:
I bought this formerly wrecked POS from a used POS dealer and I'm about ready to engage 4L, bend him over and move forward.. I have put thousands of dollars into this wreck, from steering parts, to relays and switches, to brakes to tuneups, to FI issues, and I'm just done. I've had three Gen 2 trucks and they have all been fantastic. This one, I could drive into the Pacific Ocean, and jump wildly into the air as I watched Mother Nature take it away. The wipers quit working, it's bucking and stalling on acceleration again. I replaced the fuel pump relay and the air/idle relay TWICE and it still is running like crap, now wiperless, I really want to go punch the punk *** that sold me this hunk of metal and dog crap. I need to get these two issues fixed so I can send it back to where it came from.
Old Dec 25, 2021 | 08:14 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The bucking is most likely a fuel pump. Wiper motor progeny has a bad ground (knowing chrysler)
Old Dec 26, 2021 | 12:50 PM
Tenacious C
Default So done
On the wiper motor, You can hear the motor running (only on one speed) but the arms don't move. On the fuel pump, is there any way to tell if it's the 4 or 6 pin pump before taking it out of the tank?
Old Dec 26, 2021 | 12:58 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Since the wipers aren't moving, you might want to have a look at the metal arms of the wiper linkage under the cowl to see if one of the couplers has worn out and come loose.
Old Dec 26, 2021 | 01:31 PM
Tenacious C
I'll go have a look-see, thanks
Old Dec 26, 2021 | 01:41 PM
Tenacious C
Can I tell the fuel tank size by the VIN?
Old Dec 26, 2021 | 01:51 PM
Moparite's Avatar
Moparite
With that said i think you knew what you where getting into.
Read above, No need to take it out on him you bought it.
Why fix anything if you are giving it back?
Old Dec 26, 2021 | 04:04 PM
MoparFanatic21
97 and above had 4 pin pump. You have the 26 or 34 gallon tank, both take the same fuel pump.
