94 1500 4spd auto stuck in first
Old Jan 9, 2022 | 10:05 PM
robert_metcalf's Avatar
robert_metcalf
Default 94 1500 4spd auto stuck in first
Truck refuses to shift out of first when driving. Even manually putting it into second gear it just stays in first. Bought It for my first truck and the guy told me it was a solenoid problem. Trusted him till I found out it was a hydraulic trans. Any advice on what might be wrong? And how to fix it?
Old Jan 9, 2022 | 10:23 PM
Check and see if the TV cable is bound up. If it works the way it is supposed to, it's rebuild time.
Old Jan 10, 2022 | 12:29 AM
Keith_L's Avatar
Keith_L
It's a Hail Mary but you can try a can of Seafoam Trans Tune. View it like a lottery ticket.....ie you're not really mad if you don't win
Old Jan 10, 2022 | 01:17 AM
master tech's Avatar
master tech
Site Moderator & Tech
If the transmission is a 46RH it could be a couple of problems. One it could be the governor body and valves or the Valve body itself. If the transmission is a 46RE then it the valve body..
