cranks - no spark - no codes - engine trouble lite on
2000 5.9 gas . shows milage on odometor but no codes . rpm's show on gauge . and im wondering if the fact that no codes are showing does that indicate computer issue ?
also , would a 2001 5.2 computer work in my truck ?
I would not suspect the PCM yet. If you get the "tach bounce" then it sees the crank signal and processes it. Check if there is power at the coil and if the ground side is properly switched by the PCM. You can use a simple test light for this.
A 2001 5.2 PCM should get the engine running but it won't be optimal.
