New clutch and transmission
Old Feb 22, 2022 | 04:47 PM
ChaseJardine7's Avatar
ChaseJardine7
Default New clutch and transmission
Hey guys, I致e got a 2002 Dodge Ram 2400 4x4 5.9 with the nv4500 5 speed. My clutch is toast, and 3rd gear grind going in, leading me to believe the synchros are shot. I figure if I知 going to be putting a new clutch in, I might as well put a new transmission in while I知 at it. I pull trailers occasionally, but not usually super heavy. The truck has BHAF filter, stock turbo, 75hp injectors, and a smarty tuner. I知 considering putting a bigger turbo in at some point, but nothing crazy. I知 wondering if anyone can point me in what direction to go with my new parts. I知 leaning towards a south bend clutch, but as for the transmission I知 not sure where to go. I don稚 want to break the bank, but I also want to build this to last me a long time. Any input is appreciated!
Old Feb 22, 2022 | 05:47 PM
Would a six speed out of one of the newer trucks work??
Old Feb 22, 2022 | 06:07 PM
Keith_L's Avatar
Keith_L
Looks like the SLV?
I've never opened up an NV4500 but manuals typically ain't that difficult to rebuild if you purchased a quality kit and DIY
I've also stumbled upon threads online about an NV5600 swap, but just finding a used NV5600 affordably is borderline laughable these days (check car-part.com for giggles, but be sitting down when you do)
Beyond that, no further help from the peanut gallery here....
Old Feb 22, 2022 | 06:13 PM
Ramman18's Avatar
Ramman18
Check out these guys:
https://www.midwesttrans.com/nv4500-...-transmission/
Old Feb 23, 2022 | 07:23 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You can use any transmission (even auto) if there is a controller for it. The magnum shares the same bolt pattern with the Hemi and the Cummins bolt pattern hasn't changed.
